Ga door naar hoofdinhoud
ASUS Chromebook C300MA-DH01 Audio Speakers Replacement
Wat je nodig hebt
  1. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement, Audio Speakers: stap 1, afbeelding 1 van 1
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 2, afbeelding 1 van 2 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 2, afbeelding 2 van 2
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom:
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 3, afbeelding 1 van 3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 3, afbeelding 2 van 3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 3, afbeelding 3 van 3
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 4, afbeelding 1 van 3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 4, afbeelding 2 van 3 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 4, afbeelding 3 van 3
    • Gently detach connecting cables
    • Carefully flip up the large black tab.
    • Carefully flip up the small white tab.
    • Remove its corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
  5. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 5, afbeelding 1 van 2 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 5, afbeelding 2 van 2
    • Using the JIS-J0 screwdriver, unscrew and remove from the battery:
    • (6) Six 6mm screws
  6. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 6, afbeelding 1 van 1
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
  7. ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 7, afbeelding 1 van 2 ASUS Chromebook C300MA-DH01 Audio Speakers Replacement: stap 7, afbeelding 2 van 2
    • Using the plastic opening tool, disconnect the audio connector by pushing the audio tab toward the speakers.
    • With the audio cable detached, carefully lift the speakers out of the device.
Conclusie
Gina Altimari
401 Reputatie
4 handleidingen geschreven
USF Tampa, Team S2-G5, Passmore Fall 2017 Lid van USF Tampa, Team S2-G5, Passmore Fall 2017
USFT-PASSMORE-F17S2G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 137
