Ga door naar hoofdinhoud
ASUS Chromebook C200MA DS01 Speaker Replacement
Wat je nodig hebt
  1. ASUS Chromebook C200MA DS01 Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: stap 4, afbeelding 1 van 3 ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: stap 4, afbeelding 2 van 3 ASUS Chromebook C200MA DS01 Speaker Replacement, Battery Connection: stap 4, afbeelding 3 van 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Speaker Replacement, Battery: stap 5, afbeelding 1 van 2 ASUS Chromebook C200MA DS01 Speaker Replacement, Battery: stap 5, afbeelding 2 van 2
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Speaker Replacement: stap 6, afbeelding 1 van 1
    • Pull out the battery.
  7. ASUS Chromebook C200MA DS01 Speaker Replacement, Speaker: stap 7, afbeelding 1 van 2 ASUS Chromebook C200MA DS01 Speaker Replacement, Speaker: stap 7, afbeelding 2 van 2
    • Disconnect the speaker's black bundled cable connector on the motherboard.
    • The cables are red, white and black.
    • Pinch the black bundled cable connector between your thumb and pointer finger and pull.
  8. ASUS Chromebook C200MA DS01 Speaker Replacement: stap 8, afbeelding 1 van 2 ASUS Chromebook C200MA DS01 Speaker Replacement: stap 8, afbeelding 2 van 2
    • Using your hands or the small plastic opening tool, pry the right speaker from the Chromebook.
    • There are small adhesives under the speakers that will provide moderate resistance.
  9. ASUS Chromebook C200MA DS01 Speaker Replacement: stap 9, afbeelding 1 van 2 ASUS Chromebook C200MA DS01 Speaker Replacement: stap 9, afbeelding 2 van 2
    • Disconnect the USB port ZIF(zero insertion force) connector that partially covers the left speaker.
    • Flip the ZIF retaining flap up using a spudger or your fingers.
    • Pull gently on the ribbon cable to remove it from the connector.
  10. ASUS Chromebook C200MA DS01 Speaker Replacement: stap 10, afbeelding 1 van 2 ASUS Chromebook C200MA DS01 Speaker Replacement: stap 10, afbeelding 2 van 2
    • Unravel the connecting cord between the two speakers.
  11. ASUS Chromebook C200MA DS01 Speaker Replacement: stap 11, afbeelding 1 van 3 ASUS Chromebook C200MA DS01 Speaker Replacement: stap 11, afbeelding 2 van 3 ASUS Chromebook C200MA DS01 Speaker Replacement: stap 11, afbeelding 3 van 3
    • Using the small plastic opening tool, pry the left speaker from the Chromebook.
    • Remove the speakers.
    • There are small adhesives that will provide moderate resistance.
Conclusie
Christopher Lim
779 Reputatie
7 handleidingen geschreven
Cal Poly, Team S23-G4, Livingston Spring 2017 Lid van Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
4 Leden
19 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 272
