Inleiding
This guide will take you through a step-by-step process for the removal of your Chromebook’s speakers.
Wat je nodig hebt
Remove the five 8.4 mm Phillips #0 screws.
Remove the four 4.6 mm Phillips #0 screws.
To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
Disconnect the speaker's black bundled cable connector on the motherboard.
Pinch the black bundled cable connector between your thumb and pointer finger and pull.
