Ga door naar hoofdinhoud
ASUS Chromebook C200MA DS01 Battery Replacement
Wat je nodig hebt
  1. ASUS Chromebook C200MA DS01 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 Battery Replacement: stap 3, afbeelding 1 van 1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 Battery Replacement, Battery Connection: stap 4, afbeelding 1 van 3 ASUS Chromebook C200MA DS01 Battery Replacement, Battery Connection: stap 4, afbeelding 2 van 3 ASUS Chromebook C200MA DS01 Battery Replacement, Battery Connection: stap 4, afbeelding 3 van 3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 Battery Replacement, Battery: stap 5, afbeelding 1 van 2 ASUS Chromebook C200MA DS01 Battery Replacement, Battery: stap 5, afbeelding 2 van 2
    • Remove the four 4.7 mm Phillips #0 screws that secure the battery to the Chromebook.
  6. ASUS Chromebook C200MA DS01 Battery Replacement: stap 6, afbeelding 1 van 1
    • Pull out the battery.
Conclusie
Christopher Lim
779 Reputatie
7 handleidingen geschreven
Cal Poly, Team S23-G4, Livingston Spring 2017 Lid van Cal Poly, Team S23-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G4
4 Leden
19 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 83
Altijd: 13,551
