Ga door naar hoofdinhoud
ASUS Chromebook C100PA-RBRKT07 Battery Replacement
Wat je nodig hebt
  1. ASUS Chromebook C100PA-RBRKT07 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Use the T5 screwdriver to remove the nine 2.1 mm screws from the bottom of the device.
  2. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use the iFixit opening tool to remove the 4 pads to reveal six 3.1 mm screws underneath.
  3. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the T5 screwdriver to remove the 6 3.1 mm screws under the pads.
    • There might be a layer of tape that covers the screws. Remove the tape first with a pair of tweezers.
  4. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: stap 4, afbeelding 1 van 1
    • Use the iFixit opening tool to pry the backing of the device off.
  5. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: stap 5, afbeelding 1 van 1
    • Use the tweezers to separate the cables from the motherboard.
    • You need to reach inside and peel some tape to disconnect the wire.
  6. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: stap 6, afbeelding 1 van 1
    • Use the JIS1 screwdriver to remove the four 2.1 mm screws around the audio cards.
  7. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: stap 7, afbeelding 1 van 2 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: stap 7, afbeelding 2 van 2
    • Gently disconnect the audio cards, exposing the battery.
  8. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: stap 8, afbeelding 1 van 1
    • Use the J00 screwdriver to remove the three 1.7 mm battery screws.
  9. ASUS Chromebook C100PA-RBRKT07 Battery Replacement: stap 9, afbeelding 1 van 3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: stap 9, afbeelding 2 van 3 ASUS Chromebook C100PA-RBRKT07 Battery Replacement: stap 9, afbeelding 3 van 3
    • Grip the battery and remove it from the device.
    • Remove the battery cable out of the motherboard by lifting the battery cables.
Conclusie
Tiffany Foo
289 Reputatie
2 handleidingen geschreven
Cal Poly, Team S19-G4, White Winter 2019 Lid van Cal Poly, Team S19-G4, White Winter 2019
CPSU-WHITE-W19S19G4
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 380
