Ga door naar hoofdinhoud
Aroma ARC-914SBD Push Buttons Replacement
Wat je nodig hebt
  1. Aroma ARC-914SBD Push Buttons Replacement, Lid: stap 1, afbeelding 1 van 2 Aroma ARC-914SBD Push Buttons Replacement, Lid: stap 1, afbeelding 2 van 2
    • The first step is removing the condensation catcher in order to reach the control panel. We do this by pinching the condensation catcher as shown, on both sides and pull the condensation catcher away from the cooker.
  2. Aroma ARC-914SBD Push Buttons Replacement: stap 2, afbeelding 1 van 1
    • Once the condensation catcher has been removed, set it aside for reassembly later.
    • Now make sure you have a a Phillips head screwdriver, size PH2. This tool will allow you to remove the screw that was behind the condensation catcher.
  3. Aroma ARC-914SBD Push Buttons Replacement: stap 3, afbeelding 1 van 2 Aroma ARC-914SBD Push Buttons Replacement: stap 3, afbeelding 2 van 2
    • Gently remove the piece that was held in place by the screw, you do this by pulling out from the top, then pulling up. This will expose the hinges for the lid.
  4. Aroma ARC-914SBD Push Buttons Replacement: stap 4, afbeelding 1 van 3 Aroma ARC-914SBD Push Buttons Replacement: stap 4, afbeelding 2 van 3 Aroma ARC-914SBD Push Buttons Replacement: stap 4, afbeelding 3 van 3
    • To remove the hinge, gently rotate the bottom of the rod upwards, then push inward to pull the rod out. Repeat the process for each rod. This will allow the lid to be removed.
  5. Aroma ARC-914SBD Push Buttons Replacement, Push Button Interface: stap 5, afbeelding 1 van 2 Aroma ARC-914SBD Push Buttons Replacement, Push Button Interface: stap 5, afbeelding 2 van 2
    • Locate the piece on the black plastic trim that is opposite from where the hinges were. Carefully, pry the bottom edge of this piece outward (away from the stainless steel side) about 1/4 inch to pull the tab out of it's hole. Once the bottom is pried out a bit, the tab can be seen from the bottom. Press up on the tab with a screwdriver.
  6. Aroma ARC-914SBD Push Buttons Replacement: stap 6, afbeelding 1 van 2 Aroma ARC-914SBD Push Buttons Replacement: stap 6, afbeelding 2 van 2
    • Next, you must remove the upper black trim which is connected to the inside liner with tabs. To do this you must hold the interior walls still, while rotating the trim so that the tabs line up with the slots. (tabs cannot be seen at this point, pics are to give you an idea of what you cannot see inside the device)
  7. Aroma ARC-914SBD Push Buttons Replacement: stap 7, afbeelding 1 van 2 Aroma ARC-914SBD Push Buttons Replacement: stap 7, afbeelding 2 van 2
    • Using a Phillips head screwdriver, size PH2, remove screws from the control module to expose wired connections.
  8. Aroma ARC-914SBD Push Buttons Replacement: stap 8, afbeelding 1 van 1
    • Unplug the interface from control module.
  9. Aroma ARC-914SBD Push Buttons Replacement: stap 9, afbeelding 1 van 2 Aroma ARC-914SBD Push Buttons Replacement: stap 9, afbeelding 2 van 2
    • Remove the two screws holding the cardboard cover over the Interface using a Phillips head screwdriver, size PH2.
  10. Aroma ARC-914SBD Push Buttons Replacement: stap 10, afbeelding 1 van 2 Aroma ARC-914SBD Push Buttons Replacement: stap 10, afbeelding 2 van 2
    • Using a Phillips head screwdriver, size PH2, remove the four screws holding the interface in place.
  11. Aroma ARC-914SBD Push Buttons Replacement, Push Buttons: stap 11, afbeelding 1 van 2 Aroma ARC-914SBD Push Buttons Replacement, Push Buttons: stap 11, afbeelding 2 van 2
    • These pictures identify the Push Buttons along with their corresponding solder points through the back of the circuit board.
  12. Aroma ARC-914SBD Push Buttons Replacement: stap 12, afbeelding 1 van 1
    • Heat each point with the soldering iron while pulling the Push Button out from the front in order to remove the buttons.
Conclusie
Brandon Nieves
956 Reputatie
8 handleidingen geschreven
USF Tampa, Team 2-3, Sullivan Fall 2015 Lid van USF Tampa, Team 2-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 315
