Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This repair guide will guide you through the steps to removing and replacing the power switch of your APS Tech 101629 CD-Drive.
First the external casing, and channel switch will need to be removed.
Wat je nodig hebt
Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
Find the conjoined ID cable wires that are colored black, orange, and yellow.
Lift white portion of cable wires to disconnect it.
Depress 2 pressure holds on each side of the power switch.
Press out the back of the device.
