Ga door naar hoofdinhoud
APS Tech 101629 Channel Switch Replacement
Wat je nodig hebt
  1. APS Tech 101629 Channel Switch Replacement, External Casing: stap 1, afbeelding 1 van 3 APS Tech 101629 Channel Switch Replacement, External Casing: stap 1, afbeelding 2 van 3 APS Tech 101629 Channel Switch Replacement, External Casing: stap 1, afbeelding 3 van 3
    • Pry all four of the plastic feet off the bottom of the enclosure using the iPod opening tool.
  2. APS Tech 101629 Channel Switch Replacement: stap 2, afbeelding 1 van 2 APS Tech 101629 Channel Switch Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the four screws previously covered by the feet with a Phillips #1 screwdriver.
  3. APS Tech 101629 Channel Switch Replacement: stap 3, afbeelding 1 van 2 APS Tech 101629 Channel Switch Replacement: stap 3, afbeelding 2 van 2
    • Flip the device right side up.
    • Gently slide the casing upwards and off the hard drive.
  4. APS Tech 101629 Channel Switch Replacement: stap 4, afbeelding 1 van 1
    • Flip device upside down again.
    • Gently pry the bottom gray casing away from the device.
  5. APS Tech 101629 Channel Switch Replacement: stap 5, afbeelding 1 van 2 APS Tech 101629 Channel Switch Replacement: stap 5, afbeelding 2 van 2
    • Rotate so the back of the device is facing you.
    • Gently pry the back casing away.
    • When the back casing is removed, the fan will become loose.
  6. APS Tech 101629 Channel Switch Replacement, Channel Switch: stap 6, afbeelding 1 van 2 APS Tech 101629 Channel Switch Replacement, Channel Switch: stap 6, afbeelding 2 van 2
    • Find the conjoined ID cable wires that are colored black, orange, and yellow.
    • Lift white portion of cable wires to disconnect it.
  7. APS Tech 101629 Channel Switch Replacement: stap 7, afbeelding 1 van 3 APS Tech 101629 Channel Switch Replacement: stap 7, afbeelding 2 van 3 APS Tech 101629 Channel Switch Replacement: stap 7, afbeelding 3 van 3
    • At this point, the fan is loose and can be easily moved but not disconnected.
    • Using the spudger, depress the pressure holders at all four corners of the fan.
    • Take out the fan and its cords, by pulling it outward from its cavity within the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alexis Weckel
140 Reputatie
3 handleidingen geschreven
Cal Poly, Team 24-60, Amido Spring 2011 Lid van Cal Poly, Team 24-60, Amido Spring 2011
CPSU-AMIDO-S11S24G60
5 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 44
Altijd: 874
