Inleiding
If your ANKER SoundCore does not charge, your charging port may be broken. If you wish to replace your device’s charging port, you can follow this step-by-step guide.
Before attempting to replace anything, it is recommended that you look at this device’s troubleshooting guide.
You will need an iFixit opening tool, Phillips #0 screwdriver, metal spludger, and iFixit opening pick. Soldering experience is needed.
Wat je nodig hebt
Use the plastic opening tool to pry off the screen.
Remove the screen from the device.
3 andere personen hebben deze handleiding voltooid.
