  1. Remove the 2 screws on the bottom of the device, arrows
    • Remove the 2 screws on the bottom of the device, arrows
  2. remove back cover with the help of a thin tool remove back cover with the help of a thin tool
    • remove back cover with the help of a thin tool
  3. Android Fix Kits
    Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  4. lift the lock on the touch screen connector lift the lock on the touch screen connector
    • lift the lock on the touch screen connector
  5. with the help of a heat source and a thin tool remove touch screen with the help of a heat source and a thin tool remove touch screen with the help of a heat source and a thin tool remove touch screen
    • with the help of a heat source and a thin tool remove touch screen
  6. completely remove the broken glass and replace it with the new one completely remove the broken glass and replace it with the new one
    • completely remove the broken glass and replace it with the new one
Conclusie
To reassemble your device, Follow these instructions in reverse order.
3 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
100%
irlanda helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Smilzo
5.730 Reputatie
34 handleidingen geschreven
Io ho il tablet digiland che non sta in cavo per caricare il tablet
Adriana - Antwoord
Se hai le competenze puoi provare a stringere un po’ il connettore saldato sulla scheda madre in modo che il cavetto possa fare più presa, in genere funziona anche se la soluzione migliore è sostituirlo , ma probabilmente sarà saldato quindi non è un lavoro semplice
Smilzo -
Voeg een opmerking toe
Bekijk statistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Aller tijden: 377
