Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
The Volume Rocker/Power Button Unit can sometimes break, and must then be replaced to continue to be able to adjust the volume.
Wat je nodig hebt
Remove screws
Insert spudger tool on the middle of the left side, between the white and black plastic
Slide in a plastic opening tool and use it to further pull the back off.
Work your way around the edge of the tablet with the plastic opening tool and insert more as needed
Pull off the back cover
