Ga door naar hoofdinhoud
AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement
Wat je nodig hebt
  1. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: stap 1, afbeelding 1 van 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: stap 1, afbeelding 2 van 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement, Volume Rocker/Power Button Unit: stap 1, afbeelding 3 van 3
    • Remove screws
    • Insert spudger tool on the middle of the left side, between the white and black plastic
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed
    • Pull off the back cover
  2. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: stap 2, afbeelding 1 van 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: stap 2, afbeelding 2 van 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: stap 2, afbeelding 3 van 3
    • Remove the broken volume rocker/power button unit.
    • Place the new part into the empty slot.
  3. AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: stap 3, afbeelding 1 van 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: stap 3, afbeelding 2 van 3 AKASO KingPad A90 Volume Rocker/Power Button Unit Replacement: stap 3, afbeelding 3 van 3
    • Gently press the speaker into place.
    • Replace the back cover with the new part in place.
    • Be careful to not let the volume rocker unit fall out of place.
    • Replace the screws.
Eindstreep
Miles
260 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 Lid van UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 504
