Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove screws.
Insert spudger tool on the middle of the left side, between the white and black plastic.
Slide in a plastic opening tool and use it to further pull the back off.
Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
Pull off the back cover.
Locate the speaker solder points and note where it is attached to the motherboard.
Solder the old speaker out of its mark. (Touch the tip of the solder iron to the soldering point).
Solder the new speaker onto the points where the old speaker was.
Replace the back cover with the new rear speaker unit in place.
Gently press the speaker into place.
Replace the screws.
