Ga door naar hoofdinhoud
AKASO KingPad A90 Rear Speaker Replacement
Wat je nodig hebt
  1. AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: stap 1, afbeelding 1 van 3 AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: stap 1, afbeelding 2 van 3 AKASO KingPad A90 Rear Speaker Replacement, Rear Speaker: stap 1, afbeelding 3 van 3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Rear Speaker Replacement: stap 2, afbeelding 1 van 3 AKASO KingPad A90 Rear Speaker Replacement: stap 2, afbeelding 2 van 3 AKASO KingPad A90 Rear Speaker Replacement: stap 2, afbeelding 3 van 3
    • Plug in soldering iron and let it warm up for ten minutes.
    • Locate the speaker solder points and note where it is attached to the motherboard.
    • Solder the old speaker out of its mark. (Touch the tip of the solder iron to the soldering point).
  3. AKASO KingPad A90 Rear Speaker Replacement: stap 3, afbeelding 1 van 3 AKASO KingPad A90 Rear Speaker Replacement: stap 3, afbeelding 2 van 3 AKASO KingPad A90 Rear Speaker Replacement: stap 3, afbeelding 3 van 3
    • Solder the new speaker onto the points where the old speaker was.
  4. AKASO KingPad A90 Rear Speaker Replacement: stap 4, afbeelding 1 van 3 AKASO KingPad A90 Rear Speaker Replacement: stap 4, afbeelding 2 van 3 AKASO KingPad A90 Rear Speaker Replacement: stap 4, afbeelding 3 van 3
    • Replace the back cover with the new rear speaker unit in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
Eindstreep
camchristo
71 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 Lid van UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 359
