Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
The battery can sometimes stop charging or short and must be replaced in order to turn on and function again.
Wat je nodig hebt
Remove screws.
Insert spudger tool on the middle of the left side, between the white and black plastic.
Slide in a plastic opening tool and use it to further pull the back off.
Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
Pull off the back cover.
Locate the battery unit solder points and note where it is attached to the motherboard.
Plug in your soldering iron/pen and wait the required amount of time to heat up.
Apply a small amount of pressure with the iron on the solder points until the joints come loose and the wires move freely away from the board
Remove the battery unit
5 andere personen hebben deze handleiding voltooid.
