Ga door naar hoofdinhoud
AKASO KingPad A90 Battery Replacement
Wat je nodig hebt
  1. AKASO KingPad A90 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 AKASO KingPad A90 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 AKASO KingPad A90 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Remove screws.
    • Insert spudger tool on the middle of the left side, between the white and black plastic.
    • Slide in a plastic opening tool and use it to further pull the back off.
    • Work your way around the edge of the tablet with the plastic opening tool and insert more as needed.
    • Pull off the back cover.
  2. AKASO KingPad A90 Battery Replacement: stap 2, afbeelding 1 van 3 AKASO KingPad A90 Battery Replacement: stap 2, afbeelding 2 van 3 AKASO KingPad A90 Battery Replacement: stap 2, afbeelding 3 van 3
    • Using the black plastic spudger tool, insert it under a corner of the battery.
    • Work your way around the edges to pry the battery and loosen it from the adhesive.
    • Remove the battery.
  3. AKASO KingPad A90 Battery Replacement: stap 3, afbeelding 1 van 3 AKASO KingPad A90 Battery Replacement: stap 3, afbeelding 2 van 3 AKASO KingPad A90 Battery Replacement: stap 3, afbeelding 3 van 3
    • Locate the battery unit solder points and note where it is attached to the motherboard.
    • Plug in your soldering iron/pen and wait the required amount of time to heat up.
    • Be careful with the iron as the tip is very hot and it could burn you or the tablet
    • Apply a small amount of pressure with the iron on the solder points until the joints come loose and the wires move freely away from the board
    • Remove the battery unit
  4. AKASO KingPad A90 Battery Replacement: stap 4, afbeelding 1 van 3 AKASO KingPad A90 Battery Replacement: stap 4, afbeelding 2 van 3 AKASO KingPad A90 Battery Replacement: stap 4, afbeelding 3 van 3
    • Locate the red and black wire ends of your new battery
    • Take your solder out and place it on the point with the wire
    • Use the iron/pen to slowly melt a small piece of solder onto the point and let it solidify.
    • Be careful not to use too much solder as a large blob could result in a short on your device
    • Repeat this step for the other point
  5. AKASO KingPad A90 Battery Replacement: stap 5, afbeelding 1 van 3 AKASO KingPad A90 Battery Replacement: stap 5, afbeelding 2 van 3 AKASO KingPad A90 Battery Replacement: stap 5, afbeelding 3 van 3
    • Replace the back cover with the new part in place.
    • Gently press the speaker into place.
    • Don't let the volume rocker unit fall out of place.
    • Replace the screws.
Eindstreep
5 andere personen hebben deze handleiding voltooid.
Daniel Garcia
179 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015 Lid van UMass Dartmouth, Team 4-6, Vijaybhaskar Spring 2015
UMASSD-VIJAYBHASKAR-S15S4G6
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 1,986
