Ga door naar hoofdinhoud
AEG Electrolux FM72 Disassembly for cleaning
Wat je nodig hebt
  1. AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: stap 1, afbeelding 1 van 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: stap 1, afbeelding 2 van 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Device: stap 1, afbeelding 3 van 3
    • Open the lid by pressing the grey button and lifting it away.
    • Clean each of the plastic parts with soap and water, and then leave them out to dry.
  2. AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: stap 2, afbeelding 1 van 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: stap 2, afbeelding 2 van 3 AEG Electrolux FM72 Disassembly for cleaning, Opening the Electronic Case: stap 2, afbeelding 3 van 3
    • Follow these steps to open the electronic casing.
    • Remove the four screws as shown in picture two.
    • A long Phillips screwdriver is needed for step two.
    • Remove the fifth screw at the bottom as shown in picture three.
  3. AEG Electrolux FM72 Disassembly for cleaning: stap 3, afbeelding 1 van 3 AEG Electrolux FM72 Disassembly for cleaning: stap 3, afbeelding 2 van 3 AEG Electrolux FM72 Disassembly for cleaning: stap 3, afbeelding 3 van 3
    • Gently pry the device open, using an iSesamo opener.
    • Now the I/O button can be removed.
    • Completely replacing this entire part requires desoldering wire connections.
  4. AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: stap 4, afbeelding 1 van 2 AEG Electrolux FM72 Disassembly for cleaning, cleaning electronics: stap 4, afbeelding 2 van 2
    • Now the electronic components can be cleaned using an air compressor.
    • In picture one, you can see the PCBs. Under the PCB, you'll see blue batteries. These are 2 x 3 AA rechargeable batteries .
    • If the dust bag needs to be replaced, remove its securing screws.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kevin D
7.294 Reputatie
21 handleidingen geschreven
3 opmerkingen
Hello
How can i repair the electric wire on this device please ?
Heloise - Antwoord
Hallo
Which electric wire do you mean? Can you send in a picture? Does it need soldering?
Kind regards
Kevin
Kevin D - Antwoord
How can I disassemble the motor parts for cleaning?
wongkapo0611 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 35
Altijd: 6,503
