Ga door naar hoofdinhoud
ACN Iris WG4K Video Camera Replacement
Wat je nodig hebt
  1. ACN Iris WG4K Video Camera Replacement, Handset: stap 1, afbeelding 1 van 2 ACN Iris WG4K Video Camera Replacement, Handset: stap 1, afbeelding 2 van 2
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Video Camera Replacement, Lower Case: stap 2, afbeelding 1 van 1
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Video Camera Replacement: stap 3, afbeelding 1 van 2 ACN Iris WG4K Video Camera Replacement: stap 3, afbeelding 2 van 2
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Video Camera Replacement: stap 4, afbeelding 1 van 3 ACN Iris WG4K Video Camera Replacement: stap 4, afbeelding 2 van 3 ACN Iris WG4K Video Camera Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Video Camera Replacement: stap 5, afbeelding 1 van 2 ACN Iris WG4K Video Camera Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Video Camera Replacement: stap 6, afbeelding 1 van 1
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Video Camera Replacement, Blade Connector: stap 7, afbeelding 1 van 1
  8. ACN Iris WG4K Video Camera Replacement: stap 8, afbeelding 1 van 1
    • Gently lift up on the upper case to separate it from the keypad/speaker panel.
  9. ACN Iris WG4K Video Camera Replacement: stap 9, afbeelding 1 van 1
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (5 mm) located on the upper case.
  10. ACN Iris WG4K Video Camera Replacement: stap 10, afbeelding 1 van 1
    • Rotate the top case 180 degrees so that the video screen is closest to you.
    • Lift up the bottom up so that it is perpendicular to the table (this helps you reach the two top screws).
    • The four Phillips head screws (6 mm) are highlighted by the red circles.
  11. ACN Iris WG4K Video Camera Replacement: stap 11, afbeelding 1 van 1
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm).
  12. ACN Iris WG4K Video Camera Replacement: stap 12, afbeelding 1 van 1
    • Flip the top case so that the video screen is facing up.
  13. ACN Iris WG4K Video Camera Replacement: stap 13, afbeelding 1 van 1
    • Rotate the top case 180 degrees.
    • Gently lift up on the video screen and the blade and ribbon connector to give you more slack to work with.
  14. ACN Iris WG4K Video Camera Replacement: stap 14, afbeelding 1 van 1
    • Place the video screen face down to expose the two screws. The screws are indicated by the red circles.
  15. ACN Iris WG4K Video Camera Replacement: stap 15, afbeelding 1 van 2 ACN Iris WG4K Video Camera Replacement: stap 15, afbeelding 2 van 2
    • Use the Phillips #0 Screwdriver to remove the two Phillips head screws (6 mm)
  16. ACN Iris WG4K Video Camera Replacement: stap 16, afbeelding 1 van 2 ACN Iris WG4K Video Camera Replacement: stap 16, afbeelding 2 van 2
    • Pull the ribbon connector and blade connector through the top case.
  17. ACN Iris WG4K Video Camera Replacement, Video Screen Ribbon Cable: stap 17, afbeelding 1 van 1
    • Note that the video screen is no longer attached to the top case, place in on a flat surface.
    • Gently lift of the silver casing.
  18. ACN Iris WG4K Video Camera Replacement: stap 18, afbeelding 1 van 3 ACN Iris WG4K Video Camera Replacement: stap 18, afbeelding 2 van 3 ACN Iris WG4K Video Camera Replacement: stap 18, afbeelding 3 van 3
    • The two ribbon connectors are indicated by the red rectangles.
    • Disconnect the two ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull out the ribbon cables. Gently pull out the ribbon cables.
  19. ACN Iris WG4K Video Camera Replacement, Video Screen: stap 19, afbeelding 1 van 1
    • Gently lift the video screen out of its case.
  20. ACN Iris WG4K Video Camera Replacement, Video Camera: stap 20, afbeelding 1 van 3 ACN Iris WG4K Video Camera Replacement, Video Camera: stap 20, afbeelding 2 van 3 ACN Iris WG4K Video Camera Replacement, Video Camera: stap 20, afbeelding 3 van 3
    • Flip the video screen over so that the screen itself is face-down on a flat surface to expose the camera.
    • Push up on the two clips located on the right and left side of the video camera simultaneously.
    • Gently pull the camera out.
Conclusie
Itze Kenney
1.066 Reputatie
9 handleidingen geschreven
USF Tampa, Team 20-4, Remmell Spring 2017 Lid van USF Tampa, Team 20-4, Remmell Spring 2017
USFT-REMMELL-S17S20G4
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 7
Altijd: 186
