Ga door naar hoofdinhoud
ACN Iris WG4K Motherboard Replacement
Wat je nodig hebt
  1. ACN Iris WG4K Motherboard Replacement, Handset: stap 1, afbeelding 1 van 2 ACN Iris WG4K Motherboard Replacement, Handset: stap 1, afbeelding 2 van 2
    • Press upwards with your index finger on the 4P4C connector as shown in the image.
    • Pull the connector gently out of its socket.
  2. ACN Iris WG4K Motherboard Replacement, Lower Case: stap 2, afbeelding 1 van 1
    • Flip the main body of the video phone so that the bottom is facing up.
    • Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
  3. ACN Iris WG4K Motherboard Replacement: stap 3, afbeelding 1 van 2 ACN Iris WG4K Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Lift the back case upwards to expose the inside components.
    • Red rectangles indicate the three ribbon cables.
    • The orange square indicates the blade connector.
  4. ACN Iris WG4K Motherboard Replacement: stap 4, afbeelding 1 van 3 ACN Iris WG4K Motherboard Replacement: stap 4, afbeelding 2 van 3 ACN Iris WG4K Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Disconnect the three ribbon cables from their insulation-displacement connectors by flipping up the black plastic clip.
    • Gently pull the ribbon cables out of their insulation-displacement connectors.
  5. ACN Iris WG4K Motherboard Replacement: stap 5, afbeelding 1 van 2 ACN Iris WG4K Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the blade connector from the blade receptacle by gripping the exposed area of the blade connector.
    • Gently pull the blade connector out of the blade receptacle.
  6. ACN Iris WG4K Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Gently lift up the lower case to separate it from the top case.
  7. ACN Iris WG4K Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 1
  8. ACN Iris WG4K Motherboard Replacement: stap 8, afbeelding 1 van 2 ACN Iris WG4K Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Firmly grasp the black port wall.
    • Pull up and push out to remove it from the lower case.
  9. ACN Iris WG4K Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Gently lift the motherboard out of the lower case.
Conclusie
Itze Kenney
1.066 Reputatie
9 handleidingen geschreven
USF Tampa, Team 20-4, Remmell Spring 2017 Lid van USF Tampa, Team 20-4, Remmell Spring 2017
USFT-REMMELL-S17S20G4
4 Leden
20 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 298
