Inleiding
The lower case contains the main motherboard of the ACN Iris WG4K. It is an important component because it protects the inside of the device. If it becomes badly damaged, this guide will help you replace it.
Wat je nodig hebt
Press upwards with your index finger on the 4P4C connector as shown in the image.
Pull the connector gently out of its socket.
Flip the main body of the video phone so that the bottom is facing up.
Use the Phillips #0 Screwdriver to remove the four Phillips head screws (6 mm) highlighted by the red circles.
Één andere persoon heeft deze handleiding voltooid.
