Ga door naar hoofdinhoud
ACER Aspire V5-571P-6609 Battery Replacement
Wat je nodig hebt
  1. ACER Aspire V5-571P-6609 Battery Replacement, Battery Replacement: stap 1, afbeelding 1 van 1
    • Place the laptop facing down and find the slider close to the battery.
    • Use a screwdriver or other pointed tool to slide it to the right.
  2. ACER Aspire V5-571P-6609 Battery Replacement: stap 2, afbeelding 1 van 1
    • While keeping the slider pushed to the right, use your other hand to pull the battery out from the right side to the left until it completely comes out.
  3. ACER Aspire V5-571P-6609 Battery Replacement: stap 3, afbeelding 1 van 1
    • Install the new battery with the little tabs facing the laptop. Although keeping the slider pushed to the right when installing the new battery is recommended, it is not necessary; the battery can be inserted until it clicks in place.
Conclusie
No Reassembly Required
Mauricio O.
97 Reputatie
1 Handleiding geschreven
Gateway, Team 1-1, Pee Fall 2022 Lid van Gateway, Team 1-1, Pee Fall 2022
GCC-PEE-F22S1G1
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 30
Altijd: 293
