Ga door naar hoofdinhoud
ACER Aspire E1-572-6870 RAM Replacement
Wat je nodig hebt
  1. ACER Aspire E1-572-6870 RAM Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip your laptop over so the back panel is facing upwards.
    • Locate the lock switch below the battery.
  2. ACER Aspire E1-572-6870 RAM Replacement: stap 2, afbeelding 1 van 3 ACER Aspire E1-572-6870 RAM Replacement: stap 2, afbeelding 2 van 3 ACER Aspire E1-572-6870 RAM Replacement: stap 2, afbeelding 3 van 3
    • Slide the lock switch to the right using your finger or a spudger.
    • At the same time, grasp the battery with your other hand and slide it out of the laptop.
    • Remove the battery.
    • To reinsert or replace the battery, simply line up the tabs on the battery with the laptop and slide it straight back in. There is no need to move the lock switch.
  3. ACER Aspire E1-572-6870 RAM Replacement, RAM: stap 3, afbeelding 1 van 1
    • Unscrew the one 2.5 x 8mm Phillips #0 screw from the bottom panel as designated in the image.
  4. ACER Aspire E1-572-6870 RAM Replacement: stap 4, afbeelding 1 van 3 ACER Aspire E1-572-6870 RAM Replacement: stap 4, afbeelding 2 van 3 ACER Aspire E1-572-6870 RAM Replacement: stap 4, afbeelding 3 van 3
    • Remove the back panel by carefully disengaging it around the edges and then pull upwards.
  5. ACER Aspire E1-572-6870 RAM Replacement: stap 5, afbeelding 1 van 3 ACER Aspire E1-572-6870 RAM Replacement: stap 5, afbeelding 2 van 3 ACER Aspire E1-572-6870 RAM Replacement: stap 5, afbeelding 3 van 3
    • Disengage the metal tabs located on either side of the RAM stick by pulling the tabs outward.
    • Carefully remove the RAM so you don't damage the connectors.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Cody Lim
1.404 Reputatie
7 handleidingen geschreven
Cal Poly, Team 9-6, Banghart Winter 2017 Lid van Cal Poly, Team 9-6, Banghart Winter 2017
CPSU-BANGHART-W17S9G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 889
