Inleiding
This guide will show you how to properly remove the keyboard.
Wat je nodig hebt
Flip your laptop over so the back panel is facing upwards.
Locate the lock switch below the battery.
Separate the top panel from the rest of the laptop.
Remove the yellow tape and then remove the three 1.4 x 2 mm Phillips #00 screws with a Phillips #00 screwdriver.
7 andere personen hebben deze handleiding voltooid.
Één opmerking
If installing a new keyboard, remember to pull the keyboard cable through the metal panel before screwing it back in.
