Ga door naar hoofdinhoud
ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement
Wat je nodig hebt
  1. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Flip your laptop over so the back panel is facing upwards.
    • Locate the lock switch below the battery.
  2. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: stap 2, afbeelding 1 van 3 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: stap 2, afbeelding 2 van 3 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: stap 2, afbeelding 3 van 3
    • Slide the lock switch to the right using your finger or a spudger.
    • At the same time, grasp the battery with your other hand and slide it out of the laptop.
    • Remove the battery.
    • To reinsert or replace the battery, simply line up the tabs on the battery with the laptop and slide it straight back in. There is no need to move the lock switch.
  3. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement, Hard Drive (HDD): stap 3, afbeelding 1 van 1
    • Unscrew the one 8mm Phillips #0 screw from the bottom panel.
  4. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: stap 4, afbeelding 1 van 3 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: stap 4, afbeelding 2 van 3 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: stap 4, afbeelding 3 van 3
    • Remove the back panel by carefully disengaging it around the edges and then pulling upwards.
  5. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: stap 5, afbeelding 1 van 1
    • Remove the other 8mm Phillips #0 screw holding the hard drive to the rest of the laptop.
  6. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: stap 6, afbeelding 1 van 2 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: stap 6, afbeelding 2 van 2
    • Slide the hard drive to the left using a plastic opening tool.
  7. ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: stap 7, afbeelding 1 van 3 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: stap 7, afbeelding 2 van 3 ACER Aspire E1-572-6870 Hard Drive (HDD) Replacement: stap 7, afbeelding 3 van 3
    • To remove the hard drive, pull up and to the left using the plastic tab as shown on the left side of the hard drive.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Cody Lim
1.404 Reputatie
7 handleidingen geschreven
Cal Poly, Team 9-6, Banghart Winter 2017 Lid van Cal Poly, Team 9-6, Banghart Winter 2017
CPSU-BANGHART-W17S9G6
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 27
Altijd: 3,477
