Ga door naar hoofdinhoud
3DR Iris Plus Quadcopter Motor Replacement
Wat je nodig hebt
  1. 3DR Iris Plus Quadcopter Motor Replacement, Battery: stap 1, afbeelding 1 van 1
    • Power off the drone by holding down the power button.
    • Remove the battery by disconnecting it from the main battery connector.
    • Press the power button again to ensure all electricity is discharged.
    • This step is imperative as it is dangerous to handle drone components with a running current!
  2. 3DR Iris Plus Quadcopter Motor Replacement, Propeller: stap 2, afbeelding 1 van 2 3DR Iris Plus Quadcopter Motor Replacement, Propeller: stap 2, afbeelding 2 van 2
    • Take note of the propeller cap color (either black or silver).
    • Hold down the motor assembly and twist the propeller clockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
    • Hold down the motor assembly and twist the propeller counterclockwise to unlock it (you should feel some resistance until it starts to unscrew freely).
    • This is the motor assembly.
  3. 3DR Iris Plus Quadcopter Motor Replacement: stap 3, afbeelding 1 van 2 3DR Iris Plus Quadcopter Motor Replacement: stap 3, afbeelding 2 van 2
    • Ensure that the propeller cap color (black or silver) matches the propeller screw cap color.
    • There are two different types of propellers so make sure you're using the correct one.
  4. 3DR Iris Plus Quadcopter Motor Replacement, Gimbal: stap 4, afbeelding 1 van 3 3DR Iris Plus Quadcopter Motor Replacement, Gimbal: stap 4, afbeelding 2 van 3 3DR Iris Plus Quadcopter Motor Replacement, Gimbal: stap 4, afbeelding 3 van 3
    • If your drone is equipped with it, remove the video transmitter.
    • Disconnect all cables from the gimbal.
    • If your drone has neither the gimbal or video transmitter, you can skip this step.
  5. 3DR Iris Plus Quadcopter Motor Replacement: stap 5, afbeelding 1 van 2 3DR Iris Plus Quadcopter Motor Replacement: stap 5, afbeelding 2 van 2
    • Unscrew the 16 mm screw attaching the gimbal mount to the body of the drone using the 3 mm Hex screwdriver/key.
  6. 3DR Iris Plus Quadcopter Motor Replacement: stap 6, afbeelding 1 van 2 3DR Iris Plus Quadcopter Motor Replacement: stap 6, afbeelding 2 van 2
    • Rotate the drone 180 degrees.
    • Unscrew the other 16mm gimbal mount screw using the 3 mm Hex screwdriver/key.
  7. 3DR Iris Plus Quadcopter Motor Replacement: stap 7, afbeelding 1 van 1
    • Remove the gimbal mount from the body of the drone.
  8. 3DR Iris Plus Quadcopter Motor Replacement, Bottom Shell: stap 8, afbeelding 1 van 2 3DR Iris Plus Quadcopter Motor Replacement, Bottom Shell: stap 8, afbeelding 2 van 2
    • Remove the eight 11mm screws attaching the underbody of the drone using the 2mm Hex screwdriver/key.
  9. 3DR Iris Plus Quadcopter Motor Replacement: stap 9, afbeelding 1 van 3 3DR Iris Plus Quadcopter Motor Replacement: stap 9, afbeelding 2 van 3 3DR Iris Plus Quadcopter Motor Replacement: stap 9, afbeelding 3 van 3
    • Remove the two larger, 12mm screws attached to the Go Pro mount using the 3mm Hex screwdriver/key.
    • Lift to remove the mount.
  10. 3DR Iris Plus Quadcopter Motor Replacement: stap 10, afbeelding 1 van 3 3DR Iris Plus Quadcopter Motor Replacement: stap 10, afbeelding 2 van 3 3DR Iris Plus Quadcopter Motor Replacement: stap 10, afbeelding 3 van 3
    • Feed both wires through the grill of the bottom shell.
    • Lift to remove the shell.
    • There are two cables tethering the shell to the body of the drone. It is difficult and unnecessary to remove them. Simply lay the shell to the side.
  11. 3DR Iris Plus Quadcopter Motor Replacement, Motor: stap 11, afbeelding 1 van 2 3DR Iris Plus Quadcopter Motor Replacement, Motor: stap 11, afbeelding 2 van 2
    • Ensure that the drone is in the same orientation as the picture (power connector and capacitors on the bottom).
    • Top-left motor power cables
    • Top-right motor power cables
    • Bottom-left motor power cables
    • Bottom-right motor power cables
    • Desolder the motor power cables closest to the motor that you are replacing (the cables in each corner route to the closest leg).
    • Exercise caution and follow proper desoldering procedures to ensure safety.
  12. 3DR Iris Plus Quadcopter Motor Replacement: stap 12, afbeelding 1 van 2 3DR Iris Plus Quadcopter Motor Replacement: stap 12, afbeelding 2 van 2
    • On the leg that the motor is attached to, remove the 8mm screw that holds the long leg foot in place using the 1.5 mm Hex screwdriver/key.
  13. 3DR Iris Plus Quadcopter Motor Replacement: stap 13, afbeelding 1 van 3 3DR Iris Plus Quadcopter Motor Replacement: stap 13, afbeelding 2 van 3 3DR Iris Plus Quadcopter Motor Replacement: stap 13, afbeelding 3 van 3
    • Slide the leg foot out of the leg assembly.
  14. 3DR Iris Plus Quadcopter Motor Replacement: stap 14, afbeelding 1 van 3 3DR Iris Plus Quadcopter Motor Replacement: stap 14, afbeelding 2 van 3 3DR Iris Plus Quadcopter Motor Replacement: stap 14, afbeelding 3 van 3
    • Remove each of the plastic clips holding the motor cables in by snapping them out.
    • Remove the two 9mm screws using a 2 mm Hex screwdriver/key. Once removed, the motor will hang freely from the leg chassis.
    • Remove the LED assembly by snapping it off the clips that are attached to the drone leg.
  15. 3DR Iris Plus Quadcopter Motor Replacement: stap 15, afbeelding 1 van 1
    • To remove the motor assembly, pull the motor assembly through and out of the leg chassis.
Conclusie
Duncan Applegarth
316 Reputatie
3 handleidingen geschreven
Cal Poly, Team S7-G5, Regan Winter 2020 Lid van Cal Poly, Team S7-G5, Regan Winter 2020
CPSU-REGAN-W20S7G5
5 Leden
9 handleidingen geschreven
Één opmerking
Thanks for the info Duncan , I am finding it difficult to simply snap off the led clip away from the arm is there a secret? Lol!
Kevin Lewis - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 13
Altijd: 607
