Ga door naar hoofdinhoud
360fly 4K Battery Replacement
Wat je nodig hebt
  1. 360fly 4K Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the camera upside down and peel off the two plastic screw covers with the metal spudger to reveal the screws.
    Vraag FixBot
    Voeg opmerking toe
  2. 360fly 4K Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the two 5 mm screws from the bottom of the camera with a T4 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. 360fly 4K Battery Replacement: stap 3, afbeelding 1 van 2 360fly 4K Battery Replacement: stap 3, afbeelding 2 van 2
    • Gently pry the plastic ring from around the charging plate with the metal spudger.
    • Remove the outside shell by pressing against the center of the charging plate and pulling the bottom shell away from the top shell.
    Vraag FixBot
    Voeg opmerking toe
  4. 360fly 4K Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the five 2 mm screws using a T4 screwdriver.
    • Pull off the charging plate assembly.
    Vraag FixBot
    Voeg opmerking toe
  5. 360fly 4K Battery Replacement: stap 5, afbeelding 1 van 2 360fly 4K Battery Replacement: stap 5, afbeelding 2 van 2
    • Gently pry the plug off the port on the circuit board with a plastic opening tool.
    • Remove the four 2 mm screws using a T4 screwdriver.
    • Remove the circuit board from the device.
    Vraag FixBot
    Voeg opmerking toe
  6. 360fly 4K Battery Replacement: stap 6, afbeelding 1 van 3 360fly 4K Battery Replacement: stap 6, afbeelding 2 van 3 360fly 4K Battery Replacement: stap 6, afbeelding 3 van 3
    • Remove the five 4 mm screws around the battery assembly with a T4 screwdriver.
    • Lift the battery assembly and gently pry the plug out of its port on the board below with a plastic opening tool.
    • Press the battery from the back of the battery assembly to remove it with a plastic opening tool until the glue releases the battery.
    • Potential for device damage: Do not puncture or bend the battery. Use a small amount of heat to assist in softening the adhesive if necessary.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Jacob Herron
463 Reputatie
3 handleidingen geschreven
IUPUI, Team S5-G3, Baechle Fall 2017 Lid van IUPUI, Team S5-G3, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G3
3 Leden
5Gids Commentaar
Wich one battery Can I use to replace It?
Marco Pereira - Antwoord Deel
Where can i purchase a battery
john hernandez - Antwoord Deel
I would like to purchase a 360 fly battery
Where can I buy the battery?
Mark - Antwoord Deel
Battery part number?
R H. - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 59
Altijd: 3,437
