Ga door naar hoofdinhoud
2021 Honda HR-V Rear Signal Light Bulb Replacement
Wat je nodig hebt
  1. 2021 Honda HR-V Rear Signal Light Bulb Replacement, Rear Signal Light Bulb: stap 1, afbeelding 1 van 1
    • Press the tailgate release button and lift open the rear hatch.
  2. 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 2, afbeelding 1 van 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 2, afbeelding 2 van 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 2, afbeelding 3 van 3
    • Remove the two screws beside each tail light assembly (four total) using a Phillips #1 screwdriver.
  3. 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 3, afbeelding 1 van 2 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 3, afbeelding 2 van 2
    • Place both hands on the tail light assembly and pull it directly outwards (away from the vehicle).
    • The tail light assembly will still be connected to the vehicle by wiring, so make sure to be careful when pulling the light assembly out.
  4. 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 4, afbeelding 1 van 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 4, afbeelding 2 van 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 4, afbeelding 3 van 3
    • Remove the rear signal light bulb from the light assembly by rotating the bulb socket counterclockwise.
  5. 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 5, afbeelding 1 van 2 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 5, afbeelding 2 van 2
    • Pull apart the light bulb from its socket.
    • Replace with a new light bulb and apply pressure to ensure the light bulb is securely fastened.
  6. 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 6, afbeelding 1 van 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 6, afbeelding 2 van 3 2021 Honda HR-V Rear Signal Light Bulb Replacement: stap 6, afbeelding 3 van 3
    • Slide the light assembly into the raised white plastic attached to the vehicle.
    • Align the holes on the light assembly to the holes on the vehicle and fasten the bolts into position.
Eindstreep
Guadalupe Guevara
133 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 2-8, Briggs Fall 2022 Lid van CSU Los Angeles, Team 2-8, Briggs Fall 2022
CSULA-BRIGGS-F22S2G8
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 52
Altijd: 1,081
