Inleiding
If the key fob to your 2020 Toyota Sienna has not been working correctly—not locking/unlocking, weak connection to the vehicle, or needing to use a physical key to operate your vehicle—this guide will show you how to replace the battery.
Before starting this task, make sure you have a prying tool and a CR2032 3V battery in hand. Be very cautious when separating your key fob.
Step 4 requires you to simply take out the battery and replace it with the new one then carefully close the fob back to one piece.
It's as simple as that!
Wat je nodig hebt
Position the battery on its side where the "Push" button is.
Click down on the "Push" button.
Pull out the physical key at the top of the fob on the same side as the "Push" button is located.
