Ga door naar hoofdinhoud
2017 Toyota Corolla Engine Air Filter Replacement
Wat je nodig hebt
  1. 2017 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: stap 1, afbeelding 1 van 3 2017 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: stap 1, afbeelding 2 van 3 2017 Toyota Corolla Engine Air Filter Replacement, Engine Air Filter: stap 1, afbeelding 3 van 3
    • Caution: Ensure that the vehicle is off for at least two minutes and is parked before working.
    • Pop the hood and locate the engine's air filter. It is the object circled in red.
  2. 2017 Toyota Corolla Engine Air Filter Replacement: stap 2, afbeelding 1 van 2 2017 Toyota Corolla Engine Air Filter Replacement: stap 2, afbeelding 2 van 2
    • To unclip the air filter cover, you must first take off this tube, connected to the top.
  3. 2017 Toyota Corolla Engine Air Filter Replacement: stap 3, afbeelding 1 van 2 2017 Toyota Corolla Engine Air Filter Replacement: stap 3, afbeelding 2 van 2
    • Undo the hinges at each side of the cover.
    • Put a little bit of pressure down and they should unclip easily.
  4. 2017 Toyota Corolla Engine Air Filter Replacement: stap 4, afbeelding 1 van 3 2017 Toyota Corolla Engine Air Filter Replacement: stap 4, afbeelding 2 van 3 2017 Toyota Corolla Engine Air Filter Replacement: stap 4, afbeelding 3 van 3
    • Shift the cover forward and it should come off. Have two hands on it, one at the front and the back to jimmy it out easier.
    • Do not worry about holding onto it after taking it off.
  5. 2017 Toyota Corolla Engine Air Filter Replacement: stap 5, afbeelding 1 van 2 2017 Toyota Corolla Engine Air Filter Replacement: stap 5, afbeelding 2 van 2
    • Keep the cover up enough to slide the air filter right out of the cover box.
  6. 2017 Toyota Corolla Engine Air Filter Replacement: stap 6, afbeelding 1 van 2 2017 Toyota Corolla Engine Air Filter Replacement: stap 6, afbeelding 2 van 2
    • Insert the engine air filter you've acquired into the previous air filter's slot. It should fit like a glove once slotted properly.
    • Ensure that the marked sides align properly, or else it won't fit no matter which way you put it.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 73
Altijd: 414
