Ga door naar hoofdinhoud
2017 Chevrolet Traverse Cabin Air Filter Replacement
Wat je nodig hebt
  1. 2017 Chevrolet Traverse Cabin Air Filter Replacement, Cabin Air Filter: stap 1, afbeelding 1 van 2 2017 Chevrolet Traverse Cabin Air Filter Replacement, Cabin Air Filter: stap 1, afbeelding 2 van 2
    • Open the glove compartment.
  2. 2017 Chevrolet Traverse Cabin Air Filter Replacement: stap 2, afbeelding 1 van 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: stap 2, afbeelding 2 van 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: stap 2, afbeelding 3 van 3
    • Using your fingers, twist the two fasteners counterclockwise then pull to remove them.
  3. 2017 Chevrolet Traverse Cabin Air Filter Replacement: stap 3, afbeelding 1 van 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: stap 3, afbeelding 2 van 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: stap 3, afbeelding 3 van 3
    • On the right side of the glove box, there is a damper. Pull the damper up and then out.
    • This will allow the glove box to fully extend downward.
    • To avoid damage, secure the glove compartment box with your free hand so that it does not drop when you release the damper.
  4. 2017 Chevrolet Traverse Cabin Air Filter Replacement: stap 4, afbeelding 1 van 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: stap 4, afbeelding 2 van 3 2017 Chevrolet Traverse Cabin Air Filter Replacement: stap 4, afbeelding 3 van 3
    • Use both hands to pull down on the plastic cabin air filter cover to remove the it.
  5. 2017 Chevrolet Traverse Cabin Air Filter Replacement: stap 5, afbeelding 1 van 1
    • Remove the old cabin air filter and properly dispose of it.
  6. 2017 Chevrolet Traverse Cabin Air Filter Replacement: stap 6, afbeelding 1 van 2 2017 Chevrolet Traverse Cabin Air Filter Replacement: stap 6, afbeelding 2 van 2
    • Insert the new cabin air filter into the compartment.
    • Pay special attention to the directions on the cabin air filter. The writing should be facing you and the air-flow arrow should be facing downwards.
Conclusie
Hailey Valencia
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 63
Altijd: 182
