Ga door naar hoofdinhoud
2016 SR5 Toyota Tacoma Fuse Replacement
Wat je nodig hebt
  1. 2016 SR5 Toyota Tacoma Fuse Replacement, Fuse on a car: stap 1, afbeelding 1 van 1
    • Turn the vehicle completely off and remove the key.
    • This prevents electrical shocks and keeps the fuse box area safe for physical contact.
    Vraag FixBot
    Voeg opmerking toe
  2. 2016 SR5 Toyota Tacoma Fuse Replacement: stap 2, afbeelding 1 van 2 2016 SR5 Toyota Tacoma Fuse Replacement: stap 2, afbeelding 2 van 2
    • Open the hood and identify the fuse box.
    • A lot of vehicles store the fuse box in the engine bay under plastic, if not, look under the steering wheel.
    Vraag FixBot
    Voeg opmerking toe
  3. 2016 SR5 Toyota Tacoma Fuse Replacement: stap 3, afbeelding 1 van 3 2016 SR5 Toyota Tacoma Fuse Replacement: stap 3, afbeelding 2 van 3 2016 SR5 Toyota Tacoma Fuse Replacement: stap 3, afbeelding 3 van 3
    • Refer to the fuse box diagram to locate the correct fuse.
    • Each fuse controls a specific electrical component in the car, so if the wrong fuse is chosen, nothing will change.
    • Fuse pullers are often found at the circled location.
    Vraag FixBot
    Voeg opmerking toe
  4. 2016 SR5 Toyota Tacoma Fuse Replacement: stap 4, afbeelding 1 van 1
    • Use the fuse puller to remove the fuse by pulling it straight up.
    • By pulling straight up, you can avoid bending or damaging metal parts within the fuse box.
    Vraag FixBot
    Voeg opmerking toe
  5. 2016 SR5 Toyota Tacoma Fuse Replacement: stap 5, afbeelding 1 van 1
    • Hold the fuse up to a light and check whether the metal strip inside is broken.
    • If the strip is broken, the fuse has blown and will not allow current to flow.
    Vraag FixBot
    Voeg opmerking toe
  6. 2016 SR5 Toyota Tacoma Fuse Replacement: stap 6, afbeelding 1 van 1
    • Make sure that the replacement fuse is the same amperage.
    • Push the new fuse into the corresponding spot.
    Vraag FixBot
    Voeg opmerking toe
  7. 2016 SR5 Toyota Tacoma Fuse Replacement: stap 7, afbeelding 1 van 2 2016 SR5 Toyota Tacoma Fuse Replacement: stap 7, afbeelding 2 van 2
    • Close up the fuse box and hood. Then turn on your truck!
    • If the component still does not work, you may have replaced the wrong fuse.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Test your car to ensure the broken electrical components are working. If not, you may have chosen the wrong fuse. Refer to step 3 to find out which fuse is not working. Then repeat steps 3-7.
Jack Keefe
145 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 60
Altijd: 328
