Inleiding
Use this guide to replace your brake light for 2016 Nissan Versa.
Brake lights are compulsory safety component of your car and are legally required to be functioning whenever your vehicle is operational. This guide will provide an easy-to-follow instructions to replace this vital safety component.
Before beginning, make sure to switch off your car.
In step 5, you will need to begin prying the lens from the tip before pulling it out completely. It will be the same when you are putting the lens back on. You will need to snap the plastic tip in first in step 11 before pushing the rest of the lens in.
Wat je nodig hebt
Turn off the vehicle and let it cool down for 10 minutes.
Open the trunk.
Één andere persoon heeft deze handleiding voltooid.
