Ga door naar hoofdinhoud
2016–2020 Honda Civic Tail Light Replacement
Wat je nodig hebt
  1. 2016–2020 Honda Civic Tail Light Replacement, Tail Light: stap 1, afbeelding 1 van 2 2016–2020 Honda Civic Tail Light Replacement, Tail Light: stap 1, afbeelding 2 van 2
    • Unlock and open the trunk of the car.
    • This will allow you to access the screws once it's open.
  2. 2016–2020 Honda Civic Tail Light Replacement: stap 2, afbeelding 1 van 2 2016–2020 Honda Civic Tail Light Replacement: stap 2, afbeelding 2 van 2
    • On the exterior of the trunk, take notice of the bolts connected to the tail lights. You will have to work with these.
    • A #8 socket tends to work for most Civics.
  3. 2016–2020 Honda Civic Tail Light Replacement: stap 3, afbeelding 1 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 3, afbeelding 2 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 3, afbeelding 3 van 3
    • Attach the socket to the ratchet and loosen each of the bolts, twisting the ratchet in a counterclockwise direction.
    • Use your hand to secure the tail light so it doesn't fall off once the bolts are loose.
  4. 2016–2020 Honda Civic Tail Light Replacement: stap 4, afbeelding 1 van 2 2016–2020 Honda Civic Tail Light Replacement: stap 4, afbeelding 2 van 2
    • Once you have removed the screws, place them somewhere safe because you will be using them to reattach the tail light.
    • If the screws are damaged, you can replace them with two new 8.0 mm Phillips screws.
  5. 2016–2020 Honda Civic Tail Light Replacement: stap 5, afbeelding 1 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 5, afbeelding 2 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 5, afbeelding 3 van 3
    • Pull the tail light out from the rear bumper.
    • Since this could be a tight connection, do not be afraid to use some force or you may need to move it side to side to work it out of the socket.
    • When pulling it out, be careful that you don't rip it out as it is connected to several wires.
  6. 2016–2020 Honda Civic Tail Light Replacement: stap 6, afbeelding 1 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 6, afbeelding 2 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 6, afbeelding 3 van 3
    • Once the tail light is removed, twist the light bulb connector counterclockwise to loosen and then pull it out of the socket.
  7. 2016–2020 Honda Civic Tail Light Replacement: stap 7, afbeelding 1 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 7, afbeelding 2 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 7, afbeelding 3 van 3
    • Put on gloves and pull the bulb out.
    • Pull the bulb out with caution as it can take some force to pull it out.
    • For replacement, a 7740 size bulb is recommended.
  8. 2016–2020 Honda Civic Tail Light Replacement: stap 8, afbeelding 1 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 8, afbeelding 2 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 8, afbeelding 3 van 3
    • Replace the new the light bulb by pushing it back by pushing it back into the socket.
    • It is important to use gloves when doing this as the oils on your hands and fingers will damage the bulb and cause a shorter life for the bulb.
  9. 2016–2020 Honda Civic Tail Light Replacement: stap 9, afbeelding 1 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 9, afbeelding 2 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 9, afbeelding 3 van 3
    • Reattach the tail light.
    • This won’t require much force for it to stay attached.
  10. 2016–2020 Honda Civic Tail Light Replacement: stap 10, afbeelding 1 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 10, afbeelding 2 van 3 2016–2020 Honda Civic Tail Light Replacement: stap 10, afbeelding 3 van 3
    • Use the #8 socket to replace the bolts that secure the tail light.
  11. 2016–2020 Honda Civic Tail Light Replacement: stap 11, afbeelding 1 van 2 2016–2020 Honda Civic Tail Light Replacement: stap 11, afbeelding 2 van 2
    • Lightly tighten each bolt in the clockwise direction, alternating between each one in order to avoid one misalignment.
Conclusie
Billy Ouattara
229 Reputatie
1 Handleiding geschreven
UCD-MORRIS-S23S1G5 Lid van UCD-MORRIS-S23S1G5
Community
2 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 94
Altijd: 1,061
