Ga door naar hoofdinhoud
2015-2017 Ford F-150 Cabin Air Filter Replacement
Wat je nodig hebt
  1. 2015-2017 Ford F-150 Cabin Air Filter Replacement, Cabin Air Filter: stap 1, afbeelding 1 van 2 2015-2017 Ford F-150 Cabin Air Filter Replacement, Cabin Air Filter: stap 1, afbeelding 2 van 2
    • Open the glove compartment.
    • Remove everything from inside the glove compartment.
  2. 2015-2017 Ford F-150 Cabin Air Filter Replacement: stap 2, afbeelding 1 van 3 2015-2017 Ford F-150 Cabin Air Filter Replacement: stap 2, afbeelding 2 van 3 2015-2017 Ford F-150 Cabin Air Filter Replacement: stap 2, afbeelding 3 van 3
    • Push in on the latches on the sides of the glove compartment to release it from the dashboard.
    • Set it down on the floor of the passenger side footwell.
  3. 2015-2017 Ford F-150 Cabin Air Filter Replacement: stap 3, afbeelding 1 van 3 2015-2017 Ford F-150 Cabin Air Filter Replacement: stap 3, afbeelding 2 van 3 2015-2017 Ford F-150 Cabin Air Filter Replacement: stap 3, afbeelding 3 van 3
    • Push forward on the two latches of the honeycomb filter cover.
    • Remove the cover.
    • Slide the old filter from the compartment.
  4. 2015-2017 Ford F-150 Cabin Air Filter Replacement: stap 4, afbeelding 1 van 2 2015-2017 Ford F-150 Cabin Air Filter Replacement: stap 4, afbeelding 2 van 2
    • Insert the new filter into the compartment with the arrows pointed in the direction indicated.
    • Depending on the brand, your filter may look different.
  5. 2015-2017 Ford F-150 Cabin Air Filter Replacement: stap 5, afbeelding 1 van 1
    • Insert the bottom two latches of the cover into the latch holes.
    • Swing the cover towards the filter and press down on the two side latches until they clip into place.
  6. 2015-2017 Ford F-150 Cabin Air Filter Replacement: stap 6, afbeelding 1 van 3 2015-2017 Ford F-150 Cabin Air Filter Replacement: stap 6, afbeelding 2 van 3 2015-2017 Ford F-150 Cabin Air Filter Replacement: stap 6, afbeelding 3 van 3
    • Lift the glove compartment up until it is level with the latch holes.
    • Push the latches on the left and right inward until the latches are secured.
    • Replace all the contents of the glove compartment.
    • Close the glove compartment.
Conclusie
Lucy Tinsley
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 62
Altijd: 117
