Inleiding
If your 2014 Subaru Impreza Hatchback's brake lights aren't lighting up, use this guide to replace the brake lights of the vehicle. This procedure does not require any special equipment or any expertise in home improvement.
One of the most common reasons for this issue to occur is because the fuse in the bulb has either burnt out or the bulb's connectors have become faulty. These problems can be mitigated by replacing the bulb with a new one.
Before beginning, make sure to turn off the car's engine.
Wat je nodig hebt
Één andere persoon heeft deze handleiding voltooid.
