Inleiding
If your 2014 Hyundai Veloster has burned out or dim headlights, follow this guide to replace the bulbs. You will also avoid paying tickets and reduce the chance of an accident because the headlights are out.
Before begin, you'll need H7 headlight bulbs to replace you the old ones. No tools are necessary for this repair.
- Caution: When lifting open your hood be sure its locked in place to ensure it does not fall on you while in the middle of your repair and lead to an injury.
- Note: It is illegal to drive with a broken headlight, so if yours isn't working, replace it as soon as possible to avoid a ticket.
Before starting this repair, park in safe, flat space, turn off the car, and put on the emergency brake.
Wat je nodig hebt
