Ga door naar hoofdinhoud
2014 Ford F150 Lariat Airbag Clockspring Replacement
Wat je nodig hebt
  1. 2014 Ford F150 Lariat Airbag Clockspring Replacement, Airbag Clockspring: stap 1, afbeelding 1 van 2 2014 Ford F150 Lariat Airbag Clockspring Replacement, Airbag Clockspring: stap 1, afbeelding 2 van 2
    • Disconnect the cables to your vehicle battery using a socket wrench and 10mm socket.
    • Wait 10-15 minutes for the capacitors to discharge to ensure that no power can trigger the airbag to deploy.
  2. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 2, afbeelding 1 van 2 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 2, afbeelding 2 van 2
    • Make sure that your steering wheel and wheels are in the straight position.
  3. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 3, afbeelding 1 van 2 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 3, afbeelding 2 van 2
    • Find the two holes on the sides of the steering wheel.
    • Insert a small screwdriver into the hole on one side and push to release the clip holding the airbag in place.
    • Repeat on the opposite side to release the airbag.
  4. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 4, afbeelding 1 van 2 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 4, afbeelding 2 van 2
    • Use a small flathead screwdriver to pop up the tabs on the airbag connector wires and disconnect them.
    • Disconnect the horn wire.
    • Carefully remove the airbag and set aside.
  5. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 5, afbeelding 1 van 2 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 5, afbeelding 2 van 2
    • Use a socket wrench and 24mm socket to remove the steering wheel bolt.
  6. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 6, afbeelding 1 van 1
    • Unclip and disconnect the steering wheel wires at the top.
  7. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 7, afbeelding 1 van 1
    • Pull the steering wheel away from the steering column and set aside.
  8. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 8, afbeelding 1 van 2 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 8, afbeelding 2 van 2
    • Use a socket wrench and 7mm socket to remove the three screws underneath the steering column that hold the two parts of the steering column covers in place.
    • Separate the steering column covers and push them aside to access the clockspring.
  9. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 9, afbeelding 1 van 1
    • Unscrew the broken clockspring using a T10 Torx screwdriver to remove the four screws holding it in place.
  10. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 10, afbeelding 1 van 2 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 10, afbeelding 2 van 2
    • Remove the broken clockspring and set it aside.
  11. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 11, afbeelding 1 van 2 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 11, afbeelding 2 van 2
    • Install the new clockspring using a T10 Torx screwdriver.
    • Replace the four screws and tighten them.
    • Remove the clockspring lock tab to release the new clockspring mechanism.
  12. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 12, afbeelding 1 van 1
    • Move the steering column covers back into place and replace the three screws underneath using a socket wrench and 7mm socket.
  13. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 13, afbeelding 1 van 2 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 13, afbeelding 2 van 2
    • Feed the two airbag wires through the back of the steering wheel to begin replacing it.
    • Replace the steering wheel bolt and tighten it with a socket wrench and 24mm socket.
  14. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 14, afbeelding 1 van 3 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 14, afbeelding 2 van 3 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 14, afbeelding 3 van 3
    • Reconnect the horn wires and the airbag wires.
    • Push down the tabs on the airbag wire connectors to make sure the connection is good.
  15. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 15, afbeelding 1 van 1
    • Return the airbag to its place and push it to clip it back in place.
  16. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 16, afbeelding 1 van 1
    • Reconnect the battery cables.
  17. 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 17, afbeelding 1 van 2 2014 Ford F150 Lariat Airbag Clockspring Replacement: stap 17, afbeelding 2 van 2
    • Check for a successful installation by cranking the vehicle to see the Engine OK light indicator on the dashboard.
    • Check that the steering wheel control buttons work.
Eindstreep
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 41
Altijd: 95
