Ga door naar hoofdinhoud
2013 Volkswagen Passat Rear Blinker Light Replacement
Wat je nodig hebt
  1. 2013 Volkswagen Passat Rear Blinker Light Replacement, Rear Blinker Light: stap 1, afbeelding 1 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement, Rear Blinker Light: stap 1, afbeelding 2 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement, Rear Blinker Light: stap 1, afbeelding 3 van 3
    • Open your trunk and find the access panel.
    • The access panel will be located around the corner of the indent. It is in a similar position on the opposite side as well.
  2. 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 2, afbeelding 1 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 2, afbeelding 2 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 2, afbeelding 3 van 3
    • Look around for the access panel as it might blend in well with the rest of the trunk.
    • Once found, pull back the access panel to reveal the rear components of the tail light assembly.
  3. 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 3, afbeelding 1 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 3, afbeelding 2 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 3, afbeelding 3 van 3
    • Pull back on the red tab to release the securing mechanism.
    • Remove the plug.
  4. 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 4, afbeelding 1 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 4, afbeelding 2 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 4, afbeelding 3 van 3
    • Rotate the plastic screw counter-clockwise until the screw becomes loose.
    • Remove the plastic screw.
    • The screw is the only part that holds the tail light to the vehicle. Be sure to hold the tail light from outside the vehicle so it does not fall and become damaged.
  5. 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 5, afbeelding 1 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 5, afbeelding 2 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 5, afbeelding 3 van 3
    • Remove the tail light from the rear of the vehicle by pulling it away from the vehicle.
    • If it seems stuck, give it a bit of a wiggle to loosen it.
  6. 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 6, afbeelding 1 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 6, afbeelding 2 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 6, afbeelding 3 van 3
    • Undo all 4 clips securing the grey plastic piece to the red plastic piece.
    • Lift up and separate the grey piece from the red piece.
    • There are still wires connecting the two pieces. Do not disconnect the wires.
  7. 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 7, afbeelding 1 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 7, afbeelding 2 van 3 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 7, afbeelding 3 van 3
    • Twist the lightbulb clockwise until the bulb can be removed.
    • The lightbulb has two notches on it that keep it secured. Rotate until the two notches line up with the two cutouts on the assembly.
  8. 2013 Volkswagen Passat Rear Blinker Light Replacement: stap 8, afbeelding 1 van 1
    • When inserting the new light bulb, line up the notches with the cutouts and insert the light bulb.
    • Once the light bulb has been inserted, rotate counter-clockwise to secure the light bulb.
Conclusie
To reinstall the taillight assembly, simply follow these instructions in reverse order.
7 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Best DIY instructions I’ve ever followed.
Tim MCDERMOTT - Antwoord
Thank you! The instruction had all the necessary details and really easy to follow!
Michael Romanenko - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 34
Afgelopen 30 dagen: 91
Altijd: 9,510
