Inleiding
If one of the rear blinker lights on your 2013 Volkswagen Passat has burned out, or maybe you want brighter and longer lasting LED light bulbs for your car, then use this guide to replace the rear blinker lights.
A proper functioning blinker light tells the drivers behind your vehicle what you plan on doing, as well as bringing you to the attention of drivers if your on the side of the road through the hazard lights.
Before using this guide, make sure to purchase the replacement light bulbs. LED light bulbs have proven to be brighter, more efficient, and longer lasting. The only downside an LED has to a traditional light bulb is price, as LED’s tend to be more expensive. The choice is up to you.
Although no tools are required, a small, wet rag helps clean up some old and grimy dust. A flashlight can also be used if sufficient light isn’t available.
Before starting this guide, be sure to park the vehicle in a safe and well-lit location, and preferably in the shade to keep yourself cool while working.
Wat je nodig hebt
Open your trunk and find the access panel.
The access panel will be located around the corner of the indent. It is in a similar position on the opposite side as well.
To reinstall the taillight assembly, simply follow these instructions in reverse order.
6 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Best DIY instructions I’ve ever followed.
Thank you! The instruction had all the necessary details and really easy to follow!
