Ga door naar hoofdinhoud
2013 Subaru Impreza WRX Mud Flaps Replacement
Wat je nodig hebt
  1. 2013 Subaru Impreza WRX Mud Flaps Replacement, Mud Flaps: stap 1, afbeelding 1 van 1
    • Always make sure your car is off, the parking break is applied, and you are in a safe area free from other passing cars.
  2. 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 2, afbeelding 1 van 1
    • Turn the wheels all the way towards the side you will be working on.
    • This will create easier access to the inside of the wheel well when you are replacing the mud flap.
  3. 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 3, afbeelding 1 van 3 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 3, afbeelding 2 van 3 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 3, afbeelding 3 van 3
    • Start with the front mud flaps.
    • Attach the 7/16th size socket piece to the wrench and begin removing the 7/16th diameter nuts.
  4. 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 4, afbeelding 1 van 3 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 4, afbeelding 2 van 3 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 4, afbeelding 3 van 3
    • Use your Philips Head screwdriver to unscrew the farthest #6 3/4" Stainless Philips Screw.
    • Be careful not to loose the rubber gasket attached to the screw.
  5. 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 5, afbeelding 1 van 3 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 5, afbeelding 2 van 3 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 5, afbeelding 3 van 3
    • Once the old mud flap is removed, grab your new mud flap and reattach it in the same manner as how you removed the old or broken one.
    • Repeat for opposite front mud flap.
  6. 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 6, afbeelding 1 van 3 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 6, afbeelding 2 van 3 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 6, afbeelding 3 van 3
    • For the back two mud flaps you will need to use a slightly different technique due to the limited space you will be working in.
    • Use your hands and the 10mm wrench piece to unbolt the mud flap.
    • Once you have removed the nuts, you can move on to the #6 3/4" Philips Head Screw.
    • This step will be aided by the use of an extra small Philips screwdriver.
  7. 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 7, afbeelding 1 van 2 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 7, afbeelding 2 van 2
    • Replace both back mud flaps and fasten all pieces back in place.
  8. 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 8, afbeelding 1 van 2 2013 Subaru Impreza WRX Mud Flaps Replacement: stap 8, afbeelding 2 van 2
    • Make sure the mud flaps are all properly tightened and positioned before driving your car again.
    • Enjoy your brand new mud flaps.
Conclusie
Alex Davis
101 Reputatie
1 Handleiding geschreven
Cal Poly, Team 14-3, Green Fall 2015 Lid van Cal Poly, Team 14-3, Green Fall 2015
CPSU-GREEN-F15S14G3
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 10
Altijd: 928
