Ga door naar hoofdinhoud
2013 Nissan Rogue Key Fob Battery Replacement
Wat je nodig hebt
  1. 2013 Nissan Rogue Key Fob Battery Replacement, 2013 Nissan Rogue Key Fob Battery: stap 1, afbeelding 1 van 2 2013 Nissan Rogue Key Fob Battery Replacement, 2013 Nissan Rogue Key Fob Battery: stap 1, afbeelding 2 van 2
    • Slide the small tab on the back of your fob to the left.
    • While holding the tab to the left, pull the metal key out from the top of your fob.
  2. 2013 Nissan Rogue Key Fob Battery Replacement: stap 2, afbeelding 1 van 1
    • Insert your opening pick into the small gap between the two halves of the fob and lightly pry until they separate.
  3. 2013 Nissan Rogue Key Fob Battery Replacement: stap 3, afbeelding 1 van 3 2013 Nissan Rogue Key Fob Battery Replacement: stap 3, afbeelding 2 van 3 2013 Nissan Rogue Key Fob Battery Replacement: stap 3, afbeelding 3 van 3
    • Pull the two halves of the fob apart.
    • Remove the two internal housings.
  4. 2013 Nissan Rogue Key Fob Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the battery.
  5. 2013 Nissan Rogue Key Fob Battery Replacement: stap 5, afbeelding 1 van 3 2013 Nissan Rogue Key Fob Battery Replacement: stap 5, afbeelding 2 van 3 2013 Nissan Rogue Key Fob Battery Replacement: stap 5, afbeelding 3 van 3
    • Lightly saturate a cotton swab with 70% isopropyl alcohol and wipe down the inside of the shells and the rubber pad.
    • For any small crevices dip, the toothpick into the alcohol and clean any dirt or debris.
    • Avoid wiping the circuit board and any metal components.
  6. 2013 Nissan Rogue Key Fob Battery Replacement: stap 6, afbeelding 1 van 1
    • Once the alcohol is dried, place a new battery into the battery housing with the proper orientation.
  7. 2013 Nissan Rogue Key Fob Battery Replacement: stap 7, afbeelding 1 van 3 2013 Nissan Rogue Key Fob Battery Replacement: stap 7, afbeelding 2 van 3 2013 Nissan Rogue Key Fob Battery Replacement: stap 7, afbeelding 3 van 3
    • Replace the internal components and click the two halves of the fob back together.
  8. 2013 Nissan Rogue Key Fob Battery Replacement: stap 8, afbeelding 1 van 2 2013 Nissan Rogue Key Fob Battery Replacement: stap 8, afbeelding 2 van 2
    • Slide your key back into its housing.
Conclusie
Your fob should now be fully functional!
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
OMG… I wish I had read this before and attempted to take my key fob apart. I’ve got it all scraped up and ugly from them telling me to use a screwdriver….never mind just do exacty everything this post tells you. I had no problems opening the key fob once I read this article .
Trust me do as this tells you step by step. Just don’t use a screwdriver as another on the www will inform you to do.
Thank you so much for posting this key fob battery replacement info.
Pamela Parker - Antwoord
Thanks worked perfectly and as stated above don't use a screwdriver I also read that but thank goodness I didn't have one
brandy france - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 53
Altijd: 4,846
