Ga door naar hoofdinhoud
2013 Lexus IS250 Front Dome Light Replacement
  1. 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: stap 1, afbeelding 1 van 2 2013 Lexus IS250 Front Dome Light Replacement, Headlight Dome: stap 1, afbeelding 2 van 2
    • Open the glasses compartment located near the front dome light. This is usually a straightforward latch or button release.
  2. 2013 Lexus IS250 Front Dome Light Replacement: stap 2, afbeelding 1 van 3 2013 Lexus IS250 Front Dome Light Replacement: stap 2, afbeelding 2 van 3 2013 Lexus IS250 Front Dome Light Replacement: stap 2, afbeelding 3 van 3
    • Locate two housings inisde the compartment and gently pry them open using a flathead screwdriver. Take care not to damage the surrounding plastic.
  3. 2013 Lexus IS250 Front Dome Light Replacement: stap 3, afbeelding 1 van 3 2013 Lexus IS250 Front Dome Light Replacement: stap 3, afbeelding 2 van 3 2013 Lexus IS250 Front Dome Light Replacement: stap 3, afbeelding 3 van 3
    • Utilize a star screwdriver to remove the screws holding the front dome light in place. Ensure a steady hand to prevent any accidental dropping of screws.
  4. 2013 Lexus IS250 Front Dome Light Replacement: stap 4, afbeelding 1 van 3 2013 Lexus IS250 Front Dome Light Replacement: stap 4, afbeelding 2 van 3 2013 Lexus IS250 Front Dome Light Replacement: stap 4, afbeelding 3 van 3
    • With both hands wiggle both sides of the dome. Apply a bit of force at the top to release it from its position. Be cautious to not break the plastic clips securing it.
  5. 2013 Lexus IS250 Front Dome Light Replacement: stap 5, afbeelding 1 van 3 2013 Lexus IS250 Front Dome Light Replacement: stap 5, afbeelding 2 van 3 2013 Lexus IS250 Front Dome Light Replacement: stap 5, afbeelding 3 van 3
    • Inside, youll find two bulbs on both ends. Twist them to unlock and carefully remove.
  6. 2013 Lexus IS250 Front Dome Light Replacement: stap 6, afbeelding 1 van 2 2013 Lexus IS250 Front Dome Light Replacement: stap 6, afbeelding 2 van 2
    • Carefully remove bulb. Recommended to use gloves as it can be difficult to get a grip.
  7. 2013 Lexus IS250 Front Dome Light Replacement: stap 7, afbeelding 1 van 3 2013 Lexus IS250 Front Dome Light Replacement: stap 7, afbeelding 2 van 3 2013 Lexus IS250 Front Dome Light Replacement: stap 7, afbeelding 3 van 3
    • Replace these bulbs with LED alternatives, inserting them and securing by twisting.
  8. 2013 Lexus IS250 Front Dome Light Replacement: stap 8, afbeelding 1 van 1
    • Confirm that the bulbs are functioning by checking if the lights turn on. If not double check the alignment of the bulbs to ensure proper contact.
    • Carefully place the dome back into its original position. Ensure it aligns correctly with the plastic tips. Apply gentle pressure until it clicks back into place.
Conclusie
Christian
157 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 5-3, Kershman Fall 2023 Lid van CSU Los Angeles, Team 5-3, Kershman Fall 2023
CSULA-KERSHMAN-F23S5G3
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 35
Altijd: 144
