Ga door naar hoofdinhoud
2013 Infiniti G37 Dual Air Intakes Replacement
Wat je nodig hebt
  1. 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: stap 1, afbeelding 1 van 3 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: stap 1, afbeelding 2 van 3 2013 Infiniti G37 Dual Air Intakes Replacement, Dual Air Intakes: stap 1, afbeelding 3 van 3
    • Pull the hood latch located inside the car under your remote holder.
    • Outside the car, find the lever under the actual hood, and squeeze and lift the hood.
    • Unscrew the mass airflow filter box from the frame with a Phillips #1 screwdriver.
  2. 2013 Infiniti G37 Dual Air Intakes Replacement: stap 2, afbeelding 1 van 3 2013 Infiniti G37 Dual Air Intakes Replacement: stap 2, afbeelding 2 van 3 2013 Infiniti G37 Dual Air Intakes Replacement: stap 2, afbeelding 3 van 3
    • Loosen the five bolts in the engine cover so you can have more space to access the mass airflow tubes.
  3. 2013 Infiniti G37 Dual Air Intakes Replacement: stap 3, afbeelding 1 van 3 2013 Infiniti G37 Dual Air Intakes Replacement: stap 3, afbeelding 2 van 3 2013 Infiniti G37 Dual Air Intakes Replacement: stap 3, afbeelding 3 van 3
    • Loosen the mass airflow sensor from the airflow tube and safely move it to a safe location out of the way.
    • Use vice grips to remove the clamp.
  4. 2013 Infiniti G37 Dual Air Intakes Replacement: stap 4, afbeelding 1 van 3 2013 Infiniti G37 Dual Air Intakes Replacement: stap 4, afbeelding 2 van 3 2013 Infiniti G37 Dual Air Intakes Replacement: stap 4, afbeelding 3 van 3
    • Loosen the last clamp, located at the head of the airflow tube, and give a firm tug towards you to free the entire piece.
  5. 2013 Infiniti G37 Dual Air Intakes Replacement: stap 5, afbeelding 1 van 3 2013 Infiniti G37 Dual Air Intakes Replacement: stap 5, afbeelding 2 van 3 2013 Infiniti G37 Dual Air Intakes Replacement: stap 5, afbeelding 3 van 3
    • Connect the mass airflow tube and tighten the clamps with a flathead screwdriver.
  6. 2013 Infiniti G37 Dual Air Intakes Replacement: stap 6, afbeelding 1 van 3 2013 Infiniti G37 Dual Air Intakes Replacement: stap 6, afbeelding 2 van 3 2013 Infiniti G37 Dual Air Intakes Replacement: stap 6, afbeelding 3 van 3
    • After all the clamps are tightened, place the mass airflow sensor into the tube and tighten with a Phillips #1 screwdriver.
Eindstreep
Cordell Bowens
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 26
Altijd: 884
