Ga door naar hoofdinhoud
2013 Honda Accord Headlight Replacement
Wat je nodig hebt
  1. 2013 Honda Accord Headlight Replacement, Headlight: stap 1, afbeelding 1 van 3 2013 Honda Accord Headlight Replacement, Headlight: stap 1, afbeelding 2 van 3 2013 Honda Accord Headlight Replacement, Headlight: stap 1, afbeelding 3 van 3
    • Turn your vehicle off and put the emergency brake on before you begin the repair.
    • Pull the tab beside the driver side footwell to release the hood.
    • Pull the tab locking the hood upwards.
    • Pull the hood up to its maximum position.
  2. 2013 Honda Accord Headlight Replacement: stap 2, afbeelding 1 van 2 2013 Honda Accord Headlight Replacement: stap 2, afbeelding 2 van 2
    • Attach the hood strut in its designated position.
    • The headlight bulbs can be found on the left and the right of the engine bay.
  3. 2013 Honda Accord Headlight Replacement: stap 3, afbeelding 1 van 2 2013 Honda Accord Headlight Replacement: stap 3, afbeelding 2 van 2
    • The bulb is located behind the headlight and to the left of the windshield washer reservoir.
  4. 2013 Honda Accord Headlight Replacement: stap 4, afbeelding 1 van 2 2013 Honda Accord Headlight Replacement: stap 4, afbeelding 2 van 2
    • Pull the bulb out from the socket.
    • Use a prying tool at the base of the socket to detach the bulb from the holder.
  5. 2013 Honda Accord Headlight Replacement: stap 5, afbeelding 1 van 3 2013 Honda Accord Headlight Replacement: stap 5, afbeelding 2 van 3 2013 Honda Accord Headlight Replacement: stap 5, afbeelding 3 van 3
    • Attach the new LED bulb to the socket.
    • Don't touch the new bulb with your hands or fingers. The oil from your skin can reduce the life of the bulb or cause it to shatter.
    • Place the bulb in the holder and turn it counterclockwise.
    • Once it is firmly in place, it should not budge.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Tahsin
145 Reputatie
1 Handleiding geschreven
York University, Team A-8, Morris Fall 2022 Lid van York University, Team A-8, Morris Fall 2022
YORK-MORRIS-F22SAG8
3 Leden
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 24
Afgelopen 30 dagen: 125
Altijd: 1,275
