Ga door naar hoofdinhoud
2013-2018 Jeep Wrangler Sun Visor Replacement
Wat je nodig hebt
  1. 2013-2018 Jeep Wrangler Sun Visor Replacement, Sun Visor: stap 1, afbeelding 1 van 1
    • Lower the old sun visor to the lowest position.
  2. 2013-2018 Jeep Wrangler Sun Visor Replacement: stap 2, afbeelding 1 van 2 2013-2018 Jeep Wrangler Sun Visor Replacement: stap 2, afbeelding 2 van 2
    • Locate the screw that secures the sun visor to the mounting bracket.
    • This screw is sometimes covered by a small plastic bracket.
    • Remove the plastic cover using a flathead screwdriver or trim-removing tool
  3. 2013-2018 Jeep Wrangler Sun Visor Replacement: stap 3, afbeelding 1 van 2 2013-2018 Jeep Wrangler Sun Visor Replacement: stap 3, afbeelding 2 van 2
    • Use a Torx T20 or T25 to remove the 12 mm screw that attaches the sun visor to the bracket.
  4. 2013-2018 Jeep Wrangler Sun Visor Replacement: stap 4, afbeelding 1 van 2 2013-2018 Jeep Wrangler Sun Visor Replacement: stap 4, afbeelding 2 van 2
    • Slide the old sun visor off the mounting bracket.
    • Keep the old sun visor and any hardware in case it's needed for the replacement.
  5. 2013-2018 Jeep Wrangler Sun Visor Replacement: stap 5, afbeelding 1 van 2 2013-2018 Jeep Wrangler Sun Visor Replacement: stap 5, afbeelding 2 van 2
    • Slide the new sun visor onto the mounting bracket, aligning the holes for the screws.
  6. 2013-2018 Jeep Wrangler Sun Visor Replacement: stap 6, afbeelding 1 van 3 2013-2018 Jeep Wrangler Sun Visor Replacement: stap 6, afbeelding 2 van 3 2013-2018 Jeep Wrangler Sun Visor Replacement: stap 6, afbeelding 3 van 3
    • Insert the screw into the mounting bracket and tighten it with the Torx T25 screwdriver.
    • Make sure it's snug but not too tight.
    • Tightening the screw too tight might damage the plastic.
    • If your sun visor had a plastic cover concealing the screw, put it back in place.
    • Test the new sun visor by moving it into different positions to make sure it functions correctly.
Conclusie
Piper Klein
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 46
Altijd: 260
