Ga door naar hoofdinhoud
2013-2018 Jeep Wrangler (JK) Headlight Replacement
Wat je nodig hebt
  1. 2013-2018 Jeep Wrangler (JK) Headlight Replacement, Headlight: stap 1, afbeelding 1 van 1
    • Ensure the car and headlights are turned off.
    • Open the hood of your car.
  2. 2013-2018 Jeep Wrangler (JK) Headlight Replacement: stap 2, afbeelding 1 van 1
    • Locate the headlight connector. It's a plastic piece attached to the back of the headlight bulb.
  3. 2013-2018 Jeep Wrangler (JK) Headlight Replacement: stap 3, afbeelding 1 van 1
    • Carefully pull the headlight out from its socket. Hold the base of the bulb and gently pull straight back.
  4. 2013-2018 Jeep Wrangler (JK) Headlight Replacement: stap 4, afbeelding 1 van 1
    • Unplug the old headlight from the connector. It should come off easily by pulling it away from the connector.
  5. 2013-2018 Jeep Wrangler (JK) Headlight Replacement: stap 5, afbeelding 1 van 1
    • Place a new headlight into the connector where you removed the old one. Make sure it's properly aligned.
  6. 2013-2018 Jeep Wrangler (JK) Headlight Replacement: stap 6, afbeelding 1 van 1
    • Insert the new headlight back into the headlight socket. Push it in until it's snug and secure.
  7. 2013-2018 Jeep Wrangler (JK) Headlight Replacement: stap 7, afbeelding 1 van 1
    • Check to see if the headlight works. Turn on your car and headlights to test it.
Conclusie
Nikky Torres
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 31
Altijd: 71
