Ga door naar hoofdinhoud
2012-2018 Nissan Versa Note Headlight Bulb Replacement
Wat je nodig hebt
  1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: stap 1, afbeelding 1 van 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: stap 1, afbeelding 2 van 2
    • Pull the hood lever.
  2. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 2, afbeelding 1 van 1
    • Push the lever underneath the hood to the left.
    • The lever is located in the center underneath the hood.
  3. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 3, afbeelding 1 van 1
    • Pull up the hood.
  4. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 4, afbeelding 1 van 1
    • Insert the support rod into the slot.
    • The stent is located to the right of the hood.
    • The slot is located in the underside of the hood to the right.
  5. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 5, afbeelding 1 van 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 5, afbeelding 2 van 2
    • Pull out the connector from the bulb.
    • Depending on the make of your vehicle, you may have push the tab on the connector that reads "push" before pulling out the connector.
  6. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 6, afbeelding 1 van 1
    • Twist the plastic ring out from the bulb.
  7. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 7, afbeelding 1 van 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 7, afbeelding 2 van 2
    • Pull out the old bulb.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
  8. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 8, afbeelding 1 van 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 8, afbeelding 2 van 2
    • Insert the replacement bulb.
  9. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 9, afbeelding 1 van 1
    • Twist the plastic ring back onto the bulb.
  10. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 10, afbeelding 1 van 2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: stap 10, afbeelding 2 van 2
    • Insert the connector into the bulb.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Chelsea Chineme
253 Reputatie
1 Handleiding geschreven
2Gids Commentaar
You helped to save $150
Tayuan Rebelo - Antwoord
Need instructions on head light assembly replacement for 2015 Nissan Versa note sr hatchback
Mike Baker - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 107
Afgelopen 30 dagen: 408
Altijd: 18,499
