Inleiding
Dodge Charger Key fobs are known to have their battery drained quickly. If your key fob stops working and you're unable to get into your car, don't worry! Most like, you just need to replace the battery. Though we used a 2017 Dodge Charger key fob to demonstrate, this guide should be applicable for 2011-Present Dodge Charger key fobs. When following this guide, do not use too much force as it may result in breaking your key fob.
Wat je nodig hebt
Pull the inner key from key fob.
Remove the key chain or any accessories for easy access to key fob.
