Ga door naar hoofdinhoud
2011 Ford Fiesta Headlight Replacement
Wat je nodig hebt
  1. 2011 Ford Fiesta Headlight Replacement, Indicator Bulb: stap 1, afbeelding 1 van 1
    • Park the car where you have room to work.
    • Check that the hand brake is on and the engine is off.
    • Wait for the car to cool down before opening the hood. The hot air from the engine may damage the eyes and cause burns.
    • Ensure that the car has rested for at least 30 minutes.
  2. 2011 Ford Fiesta Headlight Replacement: stap 2, afbeelding 1 van 3 2011 Ford Fiesta Headlight Replacement: stap 2, afbeelding 2 van 3 2011 Ford Fiesta Headlight Replacement: stap 2, afbeelding 3 van 3
    • Pull the hood release under the driver's dashboard towards you.
  3. 2011 Ford Fiesta Headlight Replacement: stap 3, afbeelding 1 van 3 2011 Ford Fiesta Headlight Replacement: stap 3, afbeelding 2 van 3 2011 Ford Fiesta Headlight Replacement: stap 3, afbeelding 3 van 3
    • Make sure there is space to insert fingers. If not, repeat step 2.
    • Push the yellow hood release to the left to open the hood.
  4. 2011 Ford Fiesta Headlight Replacement: stap 4, afbeelding 1 van 2 2011 Ford Fiesta Headlight Replacement: stap 4, afbeelding 2 van 2
    • Lift the hood with one hand and place the strut upright in the correct position.
    • Place strut in the hole to the left of the hood.
  5. 2011 Ford Fiesta Headlight Replacement: stap 5, afbeelding 1 van 3 2011 Ford Fiesta Headlight Replacement: stap 5, afbeelding 2 van 3 2011 Ford Fiesta Headlight Replacement: stap 5, afbeelding 3 van 3
    • Use a flathead screwdriver to loosen the lower retained screw.
    • Collect the screws and store them somewhere safe.
  6. 2011 Ford Fiesta Headlight Replacement: stap 6, afbeelding 1 van 2 2011 Ford Fiesta Headlight Replacement: stap 6, afbeelding 2 van 2
    • Remove the upper retained screw.
    • Store the screw in a safe place.
  7. 2011 Ford Fiesta Headlight Replacement: stap 7, afbeelding 1 van 3 2011 Ford Fiesta Headlight Replacement: stap 7, afbeelding 2 van 3 2011 Ford Fiesta Headlight Replacement: stap 7, afbeelding 3 van 3
    • Carefully remove the headlight.
    • The headlight is attached to three electrical connectors.
    • Gently pull up and towards your body.
    • Set the headlight to the side.
  8. 2011 Ford Fiesta Headlight Replacement: stap 8, afbeelding 1 van 3 2011 Ford Fiesta Headlight Replacement: stap 8, afbeelding 2 van 3 2011 Ford Fiesta Headlight Replacement: stap 8, afbeelding 3 van 3
    • Press both ends of the bulb container to remove the electrical connector from the bulb container.
  9. 2011 Ford Fiesta Headlight Replacement: stap 9, afbeelding 1 van 3 2011 Ford Fiesta Headlight Replacement: stap 9, afbeelding 2 van 3 2011 Ford Fiesta Headlight Replacement: stap 9, afbeelding 3 van 3
    • Pull out the bulb from the headlight.
    • Press both ends of the electrical connector to separate from the bulb container.
  10. 2011 Ford Fiesta Headlight Replacement: stap 10, afbeelding 1 van 1
    • Make sure you do not hold the glass surface with your bare hands. The bulb may malfunction from the sweat in your hands.
    • Hold the black part of the bulb.
    • The bulb might break, so be sure to wear gloves and protective glasses.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Phillip Kataswa
208 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 237
Altijd: 5,728
