Ga door naar hoofdinhoud
2011-2013 Scion tC Car Battery Replacement
Wat je nodig hebt
  1. 2011-2013 Scion tC Car Battery Replacement, Car Battery: stap 1, afbeelding 1 van 1
    • Begin by opening the hood of the car and locating the battery on the front of the driver side in the engine compartment
  2. 2011-2013 Scion tC Car Battery Replacement: stap 2, afbeelding 1 van 1
    • Using a socket wrench, loosen the 2 (5/16 inch) nuts on the top of the battery support bracket
    • Remove the bracket by lifting up
  3. 2011-2013 Scion tC Car Battery Replacement: stap 3, afbeelding 1 van 1
    • After removing the bracket, locate the supporting rod behind the battery
    • The rod is hooked on a hole in the metal behind the battery. Unhook the rod and remove it
  4. 2011-2013 Scion tC Car Battery Replacement: stap 4, afbeelding 1 van 2 2011-2013 Scion tC Car Battery Replacement: stap 4, afbeelding 2 van 2
    • Start with the negative terminal of the battery
    • Loosen the nut on the negative terminal with a 10mm socket wrench
    • Remove the wire by slightly twisting and pulling up
  5. 2011-2013 Scion tC Car Battery Replacement: stap 5, afbeelding 1 van 2 2011-2013 Scion tC Car Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the cap from the positive terminal of the battery
    • Using a 10mm socket wrench, loosen the nut on the positive terminal
    • Remove the wire from the positive terminal by slightly twisting and pulling up
    • Remove the battery by lifting it out of the engine compartment
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Travis Michael
140 Reputatie
1 Handleiding geschreven
Cal Poly, Team 8-2, Regan Spring 2015 Lid van Cal Poly, Team 8-2, Regan Spring 2015
CPSU-REGAN-S15S8G2
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 59
Altijd: 10,756
